« 1 (2) 3 »
#11 Re: A12 /14/15 ENGINE REBUILD KITs
ddgonzal Posted on: 2013/5/13 6:42
No need for a modified oil pump. You can use a sandwhich plate bolted between the Oil pump and the Oil filter. The sandwich plates are available from racing supply companies -- Ford windsor type fits the Datsun.
Nissan Competition sold a specially-fitted pump & cooler set, which looks a little more integrated.
#12 Re: A12 /14/15 ENGINE REBUILD KITs
bige Posted on: 2013/5/13 7:00
I'LL ANSWER YOUR QUESTION ( NOT COMMENT )rgjt405 -YES I HAVE SOME NEW STD OIL PUMPS.PM ME
#13 Re: A12 /14/15 ENGINE REBUILD KITs
AndyM1 Posted on: 2013/5/13 23:19
Really happy with the rebuild kit, very good quality parts. And a fast friendly service :)
#14 Re: A12 /14/15 ENGINE REBUILD KITs
bige Posted on: 2013/6/6 12:40
any interest in rebuild kits for A series.
also have a heap of engine parts,
motors,heads,cams,new extractors,manifolds and heaps more.
call or PM.Cheers
#15 Re: A12 /14/15 ENGINE REBUILD KITs
jmac Posted on: 2013/6/8 4:24
Ernie, I believe in the past you've indicated you have 2 types of cast pistons (there may be others as well) for the a15, with differing dish cc's. would it be possible to confirm what those dish sizes are for each and would it be possible to upload a pic of each type (I'm mainly looking into the shape/location of the dish, so a pic from the top down, or from an angle mostly from above or something)
And on a 'one day' sort of note, do you happen to have (or have a source for) pistons to fit an a14/15 block (with minimal oversize, though would be willing to re-think a little if they are only available in XYZ oversizes) but approx 3mm shorter compression height/pin placement. if so, what sort of dollars, and are they a flat top or dished crown? no problem whatsoever if you would prefer to respond to this last query via pm instead of here.
One last thing (that is relevent to this thread in a big way) - I recently bought carbies from Ernie. He is dead set a straight up guy - totally honest about their condition before the sale, and got them in transit (and packed them safely too!) the minute he'd been paid for em. Definitely a safe bet to deal with him.
#16 Re: A12 /14/15 ENGINE REBUILD KITs
bige Posted on: 2014/2/7 3:11
FULL A10/A12/A13/A14/A15 REBUILD KITS STILL AVAILABLE.
MADE UP TO SUIT YOUR NEEDS.
ALSO HAVE HEAPS OF OTHER H/P PARTS, NEW/USED JUST CALL OR PM.ERNIE 0412 864 741.CHEERS : (SEE PIC OF KIT PAGE 1) -o
JMAC. A15 PISTONS COME DISH WITH 10-11CC.(DEPENDING ON BRAND)
CAN DO FLATTOPS, BUT MODS REQUIRED TO RODS.
NEED TO DO MORE HOMEWORK ON SHORTER COMP HEIGHT ONES.
THANKS FOR YOUR COMMENTS.
#17 Re: A12 /14/15 ENGINE REBUILD KITS
torino120 Posted on: 2014/2/7 6:13
Will be in contact soon Bige :)
#18 Re: A12 /14/15 ENGINE REBUILD KITS
bige Posted on: 2014/2/9 1:48
ok.cheers.
#19 Re: A12 /14/15 ENGINE REBUILD KITS
Cody6936 Posted on: 2014/2/9 9:59
Do you have double valve springs for an A15, what kind of price?
#20 Re: A12 /14/15 ENGINE REBUILD KITs
lamb_daiquiri Posted on: 2014/2/10 7:19
Hey Ernie,
I was looking around for a stock flat top piston for the A15 a while back and came up with this http://datsun1200.com/modules/newbb/v ... =53664&forum=1&move=next. It looks good but I haven't had the chance to get one and measure it up.
Cheers,
« 1 (2) 3 »
