« 1 (2)
#11 Re: Timeing case cover?
D Posted on: 2014/2/7 11:56
wow thats a historian right there on the A!
love the bit on saving weight hahaha
Dave69 use anything you can get post 72.
#12 Re: Timeing case cover?
davem69 Posted on: 2014/2/7 17:09
D are u just upset because I didn't buy your super charger?
#13 Re: Timeing case cover?
Rallytwit Posted on: 2014/2/8 2:05
OK there are two styles of covers that have essentially a matched pulley:
One cover has a single mark and multiple marks/notches on the pulley in 5 degree increments.
The other cover has the 5 degree increments on the cover and a single mark/notch on the pulley.
I've installed (because I wasn't paying attention) the cover and pulley with multiple marks; I ended up marking the TDC notch on the pulley with a dab of red paint. The plus side of this is I can not check the timing advance statically (matchbox dizzy) by rotating the shaft to full advance and lining up the 15 degree BTDC marks on the pulley and cover. I do double check with a light of course.
Tom
« 1 (2)
