Part # for T50 3T 22 Spline Clutch?
From Sydney, NSW
Hi just wondering if anyone knew the part number for the t50 22 spline clutch setup or clutch kit exedy's site only seems to list 21 teeth clutches.
Cheers,
Tom
Posted on: 2014/7/29 7:26
Re: Part # for T50 3T 22 Spline Clutch?
From Perth
Your not confusing the output shaft splines with the clutch input shaft spline count are you ?
All the clutches are 21 spline
The output is either 20 or 22
Posted on: 2014/7/29 10:28
From Sydney, NSW
Thanks dattoman yes I am! So the ae86 part number you put in your post is ok for that type of setup as I'm getting my flywheel modded like yours
Posted on: 2014/7/29 10:38
