« 1 (2)
Re: Aftermarket Crank angle and tdc sensor??
Quite a regular
I have found myself a e15 dizzy. Numbers on it are... D4p80-08
It has an ignition module in it? Can I pulp that out to fit the mitsi cas? Or is the ignition module important for another function of the dizzy?
Posted on: 2015/2/10 22:54
There is no ignition module in it. Only a rotor and the CAS.
You can presumably retrofit the 4G1 Orion CAS into an E-series distributor.
The CAS in the D4P is apparently the type used by some Mitsubishi V6 engine.
Posted on: 2015/2/10 23:19
The Sirius CAS seems to be the same type. Possibly you could just swap the disc from the Hyundai into the D4P unit. See mitsi J918
Posted on: 2015/2/11 3:05
Quite a regular
This is what my dizzy looks like inside.have I bought the wrong one?
jpg  image.jpg (65.06 KB)
18160_54e0300e3e1be.jpg 600X400 px
Posted on: 2015/2/15 5:35
That depends on if you wanted a CAS or not.
That is a D4R, the best electronic ignition distributor. The CAS type is D4P which has no ignition unit in the distributor.
Posted on: 2015/2/15 8:00
« 1 (2)
