Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Cheap No Weld Injector Bung
lamb_daiquiri
Posted on: 2015/11/16 9:22
So I was thinking about how someone without the ability to weld aluminium might convert their A series to EFI and the result is this:
http://www.ebay.com.au/itm/1513564873 ... geName=STRK%3AMEBIDX%3AIT PN:mpf744 1/2 npt EDIT: ID of the bung is 13.6mm Idea being you drill/ tap the manifold and screw in a modified bung. You'd also need to make a fuel rail but you can buy the extrusion to fabricate your own. EDIT: After fitting the bung cut the top off and de-bur. I just checked with a Bosche injector (probably from a 90s commodore) and it fits really well. Just need to carefully drill out the top part of the plug. You might find other 1/2 NPT fittings are also pretty damn close. Now to hoard them in the shed for that later on project....
#3
Re: Cheap No Weld Injector Bung
Posted on: 2015/11/17 6:48
1/2 NPT HEX HEAD PLUG Aluminium blanking adapter fitting
How does that work with EFI?
#4
lamb_daiquiri
Posted on: 2015/11/17 7:19
Sorry, should have been clearer. The ID of the plug is ~13.6mm so the right size for a bosch style injector to fit inside and seal.
#5
sikyne
Posted on: 2015/11/17 10:38
Well done. Very good idea. I like it a lot! Would save heaps of time as well.
