Wanted - coupe side window rubbers
From Mordialloc Victoria 3195
Hi, Anyone know where to get the side window rubbers for a Coupe ?
Coudn't find any on Ebay
dp
Posted on: 2016/2/9 9:47
keep it simple
Re: Wanted - coupe side window rubbers
Posted on: 2016/2/9 10:08
Looked but they don't have them listed :(
Posted on: 2016/2/9 10:24
keep it simple
So it's the rubber for the pop out side glass that you're after?
Posted on: 2016/2/9 10:37
KB110 has a window seal weatherstrip that's glued to the outside of the frame. You can use the sedan strip and cut it shorter
Reportedly, 1997-2003 F150 fit when cut to length it replaces both the welt and the seal. On the B110 welt and seal are two different pieces. On the B310, it is one piece. For that matter the B310 2-door sedan seal will probably work when cut to length
Ethan used Trimlok 3/4" TrimSeal + 5/8 vinyl tube
Rockon used a similar pinch weld rubber from Clark rubber
jpg  TrimSeal with tubing.jpg (15.65 KB)
174_56ba74b1d3fff.jpg 400X300 px
jpg  TrimSeal with reinforcing tube.jpg (19.04 KB)
174_56ba74b8a2bf4.jpg 800X352 px
jpg  TrimSeal installed.jpg (24.07 KB)
174_56ba74c38560b.jpg 400X300 px
jpg  Coupe Side Window Seal.jpg (58.71 KB)
174_56ba74e60f4ab.jpg 1024X768 px
Posted on: 2016/2/9 23:09
