Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: Will these Hayashi Wheels fit?
ruredi
Posted on: 2016/4/8 4:42
I definitely want 14 x 8 -6 on the rear and understand I'd need more of a flare than 1" to make it work.
Am I going to have any other issues other than flaring the guards to get a 14 x 7 -6 on the front?
#22
ruredi
Posted on: 2016/4/8 5:43
#23
Flatto
Posted on: 2016/4/8 6:20
They look to be something like 195/45r14 to me. Although there is ALOT of stretch on those, they might even be 175/50r14.
Another thing to note is that those arches aren't just rolled, that's an entirely new arch from something like a mk1 Golf cut and welded on. If you want to run a wheel that wide, you might want to try ziggy's method he used on his green ute, although he went for 13x7, not 14x8. http://datsun1200.com/modules/newbb/v ... SC&topic_id=64189&forum=9
#24
ruredi
Posted on: 2016/4/8 6:38
The panel shop will be doing the flare job so will discuss with them when the time comes. I was thinking of using a 195/60R14 tyre?
#25
Flatto
Posted on: 2016/4/8 6:46
This website is your friend for tyre stretch:
https://tyrestretch.com/#homelist The closest thing on that website to a 195/60r14 on an 8" wide rim is https://tyrestretch.com/8.0-195-55-R14/
#27
ruredi
Posted on: 2016/4/8 7:25
195/55 and 195/45 doesn't look overly stretched to me.
DDgonzal ute has 14x8 with 195/60 and it looks fine!
#28
Posted on: 2016/4/8 8:24
Looks fine, but it voids the Advan tyres warranty. The tyre was designed to fit on maximum of 7" wide wheel. If you want the look gotta pay the price
The sedan looks to me to be stretched even more than that
#29
zigmondo
Posted on: 2016/4/8 9:24
If your really set on a look , get the wheels and tyres first, as sugested before, then work in the flares, wheel arch cuts, castor bars afterwards to suit - anything is possible and from the work youve done already , should look sweet
#30
ruredi
Posted on: 2016/4/11 9:17
All the negative comments about stretched tyres and voided warranties makes me scared. I do love the look that but I do want it to be safe.
The manufacturer generally only shows one wheel in a particular offset (usually the negative ones because they look better) and it's hard to gauge whether or not I'd be happy with a more positive offset. Been browsing the internet trying to find real photographs of Hayashi wheels and find the specific offset. Came across this Corolla. ![]() ![]() ![]() ![]() ![]() ![]() Wheels are Hayashi ST. Fronts are 14 x 6.5 +13 offset and the rear is 14 x 7 +7 offset. Surprisingly, I actually don't mind the amount of dish. which got me thinking. If I was to put a 14 x 6.5 rim on the front, I can put a 185 tire on it (within manufacture recommendation?). I now imagine the +13 is an issue with clearance to the strut? The rear could sport a 14x7 +7 and run a 195 tyre which is also within the manufacturer recommendation? You can view topic.
