Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#61
Re: A12 Cross Flow Head
D
Posted on: 2018/12/14 2:56
https://www.youtube.com/watch?v=pk8ZrN__nmA
if only you can get a pic of the chambers from this engine they made a 3cyl 1.6L version that made 250hp!!! sounds better than almost anything except the 510 BRE
#62
nickmitty
Posted on: 2018/12/14 3:35
11,000 rpm V12 sounds better than my bike redlining .
#63
D
Posted on: 2018/12/14 11:28
Does sound crisp for a 6L! pity we would never see the chamber design
but Im guessing they just lifted off a Hayabusa or Ninja design
#64
Mattndew76
Posted on: 2018/12/14 11:43
I imagine the chamber design wouldn't be that exotic. The Hyabusa design isn't anything spectacular, Shallow dome with two intake and two exhaust. Spark right in the very center of the cylinder.
Anyone try to adapt this cylinder head to the A12 block, or is the symmetry off?
#65
D
Posted on: 2018/12/15 5:10
Very true nothing too uncommon for bike engines these days
but if an NA 1.6L can make 300hp then thats crazy hp yet the AM is unique as its a high hp NA engine thats not boosted. Simon already adapted a late Honda black hawk head on an A12 not easy alot of work but for now the 8v A series head with boost is doing the honours needed. Plenty of Twin cam head conversions done on the A series by now but no one offers a kit anymore like Rob did. Mazda b6 heads are still commonplace and popular support aftermarket s/ tuning thats hard to beat. 160kws atw from a b6 is quite nuts for a miata yet cannot image what that would be like on a 1000/1200! yet it is possible boring an A15 to 78mm to suit the B6/Z5 bores The Ford Kent head for your search on OHV possibilities with little capacity 158hp atw that non-crossflow Kent Seems to have better port angles and layout than Nissan A http://www.rsmotorsport.com.au/forums/viewtopic.php?f=11&t=2884 Cast iron head below with 1500cc and 163hp a@ 8000rpm http://www.rsmotorsport.com.au/forums/viewtopic.php?f=11&t=2884 Yet Nissan A series has better combustion chamber design
#66
D
Posted on: 2018/12/19 13:01
Another possibility Matt is to evenly space the A series chamber
rather than offset chambers like factory versions have. This will allow full 83mm sleeves on any A series as mentioned by Lemonhead machinist who sleeved and bored it out to 82mm. 83,5mm was the max safe possibility but no room for rebuilds. Alternatively flat plane A12 cranked ohv v8 with separate crankcase and cylinder case to save on billet sizes. A12 rods are way wider than todays v6 engines by almost 2 fold so custom bike ones could share the same main bearings 3L ohc v8 would be sweet.
#67
Mattndew76
Posted on: 2018/12/22 10:09
I will be moving into rocker arm design while I'm off for the holyday I think I have a reasonable head design I can machine with minimal issue. I will machine a proto head to be sent off for valve seats and guide installation in the end of January. If that don't happen then I have gotten caught up with putting my Ford back together.
#68
D
Posted on: 2018/12/26 5:31
OHV 3 or 4 valve heads would be nuts, Ford Chev and privateers sold and played with them as you know.
![]() ![]() http://speedtalk.com/forum/viewtopic. ... 0617aa7f&start=45#p523321 https://www.yellowbullet.com/forum/showthread.php?t=428830&page=2 http://www.valleyhead.com/thunder.html no belts or chains on the front would be nice and compact http://i57.tinypic.com/flyovt.jpg
#69
Mattndew76
Posted on: 2018/12/29 2:51
Holy hell thats an awesome mechanical setup D.
I’m going to see if I can duplicate a similar setup
#70
D
Posted on: 2018/12/29 13:21
Its pretty off the scales crazy I agree!
The benefits are nuts as the valves are smaller the spring rates are probably equal to big valves with big springs. The shafts are very simple and the pushrod to the valves acts like a pivot lever therefore less stress than direct actuation. Exhaust valves being smaller also help. It would be lighter than 2 extra camshafts overall and because there are two roller shafts where the lever action occurs with lubrication there is very well distributed forces separating both in and ex. valves and seats can be lifted from factory honda, suzuki, yamaha or kawasaki take your pic! Quote: The cam grinds used are a lot milder than traditional 2-valve big-block cams because of the extra valves' greater flow window area. For example, a standard high-performance big-block Chevy 2-valve motor uses one 2.19-inch intake and one 1.88-inch exhaust valve per cylinder; these valve sizes have a circumferential window area of 3.44 and 2.95 inches, respectively. By contrast, the Thunder Power head use two 1.75-inch intake and two 1.50-inch exhaust valves per cylinder for a total circumferential window area of 5.50 and 4.71 inches, respectively. standard A12-A15 cams would be all they need :) cheaper than twin cam custom grinds 62% increase in valve circumferential window area over 2 valves with same bore. Relatively flat rocker covers as well due to less lift required therefore shorter rocker shaft towers etc. ![]() You can view topic.
