Re: 1200 coupe-what diff
I gotta go with Sidedraught here. The H145 diferential is not 'weak",... when used in the application for which it was designed, IE, in a stock-ish 1200.
I used one for about 200,000 miles in my 1000 sedan with improved 1200GX & five speed. A lot of the trick is in knowing how to drive, & un-necessarily broken components are a sure pointer to those who dont.
If you plan to use a significantly more powerfull engine, then abuse the crap out of it, you can do what 1200 owners have been diong for decades & use the Datsun 1200 ute rear axle assembly. These will interghange into 1200's & they use the stronger H165 diferential. Suitable ratio diffs can be sourced from 910 Bluebirds & Stanzas.
These 1200 Ute rear axle housings will accept the rear disc brakes from the 910 Bluebird TRX & LX models,... so i believe.
Respect your Datsun,... treat it well.
Posted on: 2005/2/12 8:44
Love your Datsun.
Treat it well.
Subject Poster Date
     1200 coupe-what diff brardey 2005/2/11 9:56
       Re: 1200 coupe-what diff sidedraught 2005/2/12 3:16
         Re: 1200 coupe-what diff Dodgeman 2005/2/12 8:44
