#1 R31 skyline struts into datsun 1200 ute??
creativepunka Posted on: 2005/5/16 6:33
Hey i want to no if its possible to fit R31 skyline struts under my 1200 ute. I want to do this for the r31 brake and that i can put some big wheels under it. is it possable? how much work?
#2 Re: R31 skyline struts into datsun 1200 ute??
LAGWAGON Posted on: 2005/5/16 10:36
it is possible but there is a bit of mucking around, you need a welder for starters.
the spring perch needs to be cut off and a perch from a stanza to be welded on in its place, but in the position which gives you your desired ride height.
there is also a bit of mucking around to be done with which strut top you use. having said that the brakes are good to use and the stub axle angle allows you to run a broad range of wheel. but as the stub axle angle is different, some ugly positive camber kreeps in. could be fixed with adjustable strut tops but the list goes on really.
on the positive side it is a short strut to start with and the brakes are large (for a 1200) vented disks with nice big single piston calipers.
not a conversion for the "bolt in" people, but a good one nonetheless
#3 Re: R31 skyline struts into datsun 1200 ute??
woodydat Posted on: 2005/5/16 15:29
tlkn bout strut changes, i need a set of stanza struts, can anyone PLEASE help me out here? im in need of stanza struts!
#4 Re: R31 skyline struts into datsun 1200 ute??
2332owner Posted on: 2005/5/17 2:17
Anyone have an idea how much extra track the R31 struts will give a 1200?
#5 Re: R31 skyline struts into datsun 1200 ute??
Grunterhunter Posted on: 2005/5/17 11:17
I asked Baz from Datsports that question about his R31 conversion struts, and he didnt give me a straight answer, other than they fit perfectly with 15x6.5 rims with a 38 offset..... Makes it difficult if you are trying to put in a proposal to the RTA, and they expect you to tell them the new track before you have done the job!!
#6 Re: R31 skyline struts into datsun 1200 ute??
creativepunka Posted on: 2005/5/17 12:15
yer i want to no this for an rta proposal. I am good with a welder and think i mite be able to adapt it, just thort id ask for opinion. why the stanza springs and seats? are the r31 springs too large in diameter? thanks for the input guys.
#7 Re: R31 skyline struts into datsun 1200 ute??
Grunterhunter Posted on: 2005/5/18 12:03
Yeah, R31 spring diameter is huge.
Lagwagon: you said thet there were issues with positive camber on this conversion- Is that with or without replacing the lower control arms with stanza or sunny arms?
#8 Re: R31 skyline struts into datsun 1200 ute??
LAGWAGON Posted on: 2005/5/18 12:43
yeah the spring diameter is massive, has to be changed.
Grunterhunter: well i took some lower control arms off a sunny at the wreckers as that is what the all knowing (cough) Baz told me to do. they ended up being the same length as the stockies, but allowed for all the other larger stuff (steering arms etc.) to be bolted up with them. my car sits at a nice height at the front but has about 1 degree pos camber. this can't be remedied by extending the lower control arms as the wheels i am running would hit the guards.
the wheels you are running will play a big part in how it turns out - silvia type offset rims would allow for some extra length arms as they pull the wheel in close to the strut. i made mine around the rims i am running and i suggest you do something similar. i am going to end up needing adjustment in the camber from a camber top. i have a few theories about them so i'll be having a go at them soon...ish. definately making a custom setup like this for your car, but its easy to stuff it up, so keep researching as you are and you should end up with a good result.
#9 Re: R31 skyline struts into datsun 1200 ute??
WhiteSedan Posted on: 2005/5/18 15:22
Just to clarify, all datsun/nissan struts save 1200 and 120y up to and including R31 skyline(i havent looked at R31) and 280zx will bolt to a stanza or sunny steering arm, the sunny lower control arm is same length as a 1200 one but will accept a larger steering arm and ball joint. So you can use the sunny control arm with other struts to keep the same 1200 width or if you want wider track use the stanza arm. Then instead of having to modify 120y castor rods like every one does use the sunny rods. The sunny ball joints and the stanza ones are the same. Use stanza or sunny outer tie rods and stanza sway bar links because these are thicker. And i think that is all.
#10 Re: R31 skyline struts into datsun 1200 ute??
LAGWAGON Posted on: 2005/5/19 3:10
oh yeah, thats the other thing the bottom of the r31 strut does not fit on a 1200/stanza arm. a small ring spacer needs to be machined up.
