Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Will it fit, and is it a good option?
ernal
Posted on: 2002/8/18 13:55
I have been offered a gearbox and diff from a 1000 ute.
I was wondering if the box would bolt onto an a15. I was also wondering would the a15 break the box and diff. The a15 is standard with webers, and probably wont have any major work done on it for a while Thanks
#2
Re: Will it fit, and is it a good option?
b310gx
Posted on: 2002/8/19 2:36
got to ask,is it a standard 1000 gearbox,or did it come out of a 1000,but was originally from something else.if it's a stock 1000 box,it's life expectancy is not great,as these boxes are puny.as for the diff,the alloy centre will bolt into the 1200 housing,has a 4.375:1 or 4.625:1 ratio(if it hasn't been swapped for something else) & should take a mild a15 easily.good ratio for motorsport.the ute housing is also narrower than standard 1200,so can't be used under a 1200 without moving spring perches. so yes,no & maybe.
#3
ernal
Posted on: 2002/8/19 4:27
Not sure on whether the gearbox is original 1000 or not. I will certainly ask now 8)
The diff would be going into my B120 ute, so i would imagine the suspension etc wouldnt need changing in that case?
#4
shoom
Posted on: 2002/8/19 12:13
I have an A15 in my 1000, with a dgv weber and extractors.. so far the standard box has held together. my only worry is it still has the 1000 clutch in it. this will be rectified when I get my GX 5 speed ;)
#5
b310gx
Posted on: 2002/8/20 11:43
when you say b120 ute,is it a h145 or a h165 diff,they aren't interchangable.if it's the early one (h145),it'll fit.as for the gx 5-speed in shoom's 1000,1:1 fifth or overdrive?.the 1:1 five speeds don't have good lubrication to the input shaft bearing,so will have a short life span.if this is the gearbox you have,the minute the box gets noisy,pull it out & put new bearings in it.if you don't,this bearing seizes on the input shaft,which destroys the input shaft,the cluster gear & whatever gear you're in at the time.had this happen to me at the street drags once,& it was a very expensive repair.if it's an overdrive box,shouldn't be a problem,except for the bashing of the transmission tunnel for clearance.
#6
Posted on: 2002/8/20 22:10
Which year did the utes start using h165 diffs?
#7
ernal
Posted on: 2002/8/21 2:20
How do I identify which diff it is?
Does it have H145 or H165 stamped on it somewhere?
#8
1200rallycar
Posted on: 2002/8/21 9:34
dont think anythings stamped
went out and took ROUGH measurements of the bit in the centre just from top to bottom h145: 7" or 180mm h165: 8.5" or 215mm theres a big enough diffrence, with this you should have a pretty good idea
#9
mr_nismo4
Posted on: 2002/9/4 11:53
Does anyone know what the differences are between H145 and H165? Is one stronger than the other?
What years did the utes come out that had these in them? Cheers
#10
1200rallycar
Posted on: 2002/9/4 12:09
as i showed before the h165 is bigger, it has bigger axles and everything and is a stronger diff, main reason i went to it is becuase you can get 4.1:1 and 4.875:1 ratios quite easy and its stronger, it is the same diff that the bluebirds and vanettes had, not sure about what utes had it
edit: ute h165 is same width as 1200 diff but bluey and vanette ones are wider You can view topic.
