Re: How do you to install an electronic fuel pump on a a12?
From Melbourne, Australia
you kinda need to explain how you plan to set it up
installing the pump is as simple as a positive and negative wire, an in and out fuel line, and some sort of bracket to hold it down
and you need to remove/block the old mechanical pump
but without knowing what pump and regulator you plan to use its hard to give any further advice
Posted on: 2005/10/24 14:17
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Subject Poster Date
     How do you to install an electronic fuel pump on a a12? chris1200t 2005/10/24 12:48
       Re: How do you to install an electronic fuel pump on a a12? urban_myth 2005/10/24 12:52
         Re: How do you to install an electronic fuel pump on a a12? chris1200t 2005/10/24 13:01
           Re: How do you to install an electronic fuel pump on a a12? 1200rallycar 2005/10/24 14:17
             Re: How do you to install an electronic fuel pump on a a12? ddgonzal 2005/10/25 7:59
               Re: How do you to install an electronic fuel pump on a a12? chris1200t 2005/10/25 8:53
                 Re: How do you to install an electronic fuel pump on a a12? ddgonzal 2005/10/27 4:53
                 Re: How do you to install an electronic fuel pump on a a12? ang94541 2005/10/27 9:36
                 Re: How do you to install an electronic fuel pump on a a12? hotrod88 2005/10/27 22:09
