Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
help needed with wheels
boofhead
Posted on: 2006/1/23 7:20
hoping i can get some ideas from the ever expanding knowledge of fellow datto lovers .....
question - anyone know of a late'ish model car that runs 13x5.5" rims with a 114pcd ?? offsets no issue here ..... just trying to find one is hard enough thanks in advance guys
#2
Re: help needed with wheels
matty
Posted on: 2006/1/23 7:44
Hyundai are the only company I can think of off the top of my head. Type PCD into Google and do some research.
#3
boofhead
Posted on: 2006/1/23 8:04
call me retarded if you will, but typing pcd, 114, 114.3, steel or any of the likes really only comes up with aftermarket alloys ??
i know hyundai have the right pcd but i'm after what car may have had a 13x5.5" rim ??
#4
1200rallycar
Posted on: 2006/1/23 8:28
im guessing the early exa's maybe maybe... but they probably dont fit into "late'ish" category
they were 4x114.3 and offset is not too bad for a 1200 either, i got some 13" mags off one once andd used them on my green coupe for a while (stanza struts)
#5
Posted on: 2006/1/23 10:33
i think hes after just steel rims witheither 13 x 5 or preferably 13 x 5.5. ive been searching through data all day and cant find 13 x 5.5 only 13 x 5 or 14 x 5 or 5.5...
its cause wheels are identical and one with a different offset lookning for a newer set for boof now
#6
phunkdoktaspok
Posted on: 2006/1/23 13:46
Did you check out any nissan vans?
#7
matty
Posted on: 2006/1/24 0:12
The first series of the rounder Hyundai Excels had 13" steelies didn't they?
Boofhead - do a search to see what makes use the same pcd and then search the manufacturer's spec sheets.
#8
Posted on: 2006/1/24 3:31
this is what ive been doing for boof as i have some resources available at the place you go when you are not at home.
180b or similar would be perfect but theres a style hes after....
#9
Posted on: 2006/1/24 3:33
I'm not aware of *any* front-wheel drive cars with this wheel bolt pattern. Many rear-wheel drive cars had 4 x 114pcd
This means 4 bolts on 4-1/2 inch circle -- the metric equivalent to 4.5 inches is 114.3 mm. For a list of many vehicles that use this bolt pattern, see our Tech Section article Suspension & Brakes Overview.
#10
Posted on: 2006/1/24 3:40
apparently preae92 toyota corolas here had the 114.3 stud pattern as did the cc lancer gsr (it uses 14inch tyres though) and some huyundai excells and lantras....
