Why on earth would you want to do that?
When properly lowered, the distance from the front spring leaf to the compression bump stop remains unchanged.
Do not lower the front suspension by any significant degree as the little suckers get a bit squeezy in there if you are running wheels that are much bigger than standard & the limit of legal lowering id defined by the distance from the ground to the center of the headlight. It doesn't take much to reach this limit.
I believe that the rubber block beteen the lower suspension arm & the spring is still available & if so, then get a pair.
The method of lowering is to cut down the overall height of this block by a small amount & refit it.
If you screw it up, or get pinged by the law, it's always good to know that you have the right parts at hand to restore the front suspension height.
If you don't have the spare suspension blocks & you overdo it, ...... you're screwed.
