Roll cage
From Melbourne, Australia
A guy i knows selling a 6pt roll-cage for a 1200 4dr sedan and i want to know if it'll fit in my coupe. if this helps: it is bolted to rear wheel arches, behind seats on floor and on floor in front foot well, my main concern is though the height of the cage as it has a high bar across the top just behind the front seats filling the roof area (about 2cm between roof and cage) only behind the front seats (the rest is a couple of centimeters lower again therefore no concern). Im not sure whether the coupe has a lower roof? in paticular at this point? or is it the same? (i presume the distance from the wheel arch to front feet well will be close enough for cage to fit). i may be able to get some pictures if that might help. thanks for any thoughts
Posted on: 2002/5/13 5:41
Subject Poster Date
     Roll cage 1200rallycar 2002/5/13 5:41
       Re: Roll cage rally-a-coupe 2002/5/13 6:03
         Re: Roll cage Will 2002/5/13 6:31
       Re: Roll cage teretonga 2002/5/13 11:07
         Re: Roll cage 1200rallycar 2002/5/13 13:43
           Re: Roll cage Jesse 2002/5/13 15:37
             Re: Roll cage 1200rallycar 2002/5/14 5:46
               Re: Roll cage rally-a-coupe 2002/5/14 6:38
                 Re: Roll cage 1200rallycar 2002/5/14 10:03
