Dual carb heat shield question
From SoCal
Doing some test driving. A15 into MG Midget, H89 head port matched to GX intake.
I am using a pair of SU HIF4 carbs on the GX intake with a sectioned MGB heat shield. I am not a very good welder and the heat shield was warped a little. I did what I could but now that it's all hooked up and running I have a vacuum leak between the spacers and the shield.
I am using the 210 exhaust manifold with it's factory heat shield. Could I get away with running the carbs without the carb heat shield? Just take it off, rig up mounts for the cables and go. It would be intake, phenolic spacers and carbs only. Will the exhaust manifold heat shield be enough or am I out of my flipping mind?
Posted on: 2014/6/3 1:07
Edited by 58custom on 2014/6/3 1:29:32
1969 MG Midget, A15/60A
Subject Poster Date
     Dual carb heat shield question 58custom 2014/6/3 1:07
       Re: Dual carb heat shield question ddgonzal 2014/6/3 22:33
