R32 rear brakes and rotors on a h165 diff ?
From New zealand
Hi
I'm planning on doing a drum/disk conversion on my nissan sunny ute 89 model With a h165 diff Its has already had the front disk conversion with s13 brakes ....I've been doing some research on tech wiki an have found you can use the r31 set up can you also use r32 brakes as well ? If so how do they mount to the diff ? Is their an aftermarket bracket you can buy to use to fit the calipers ? And do you need to modify the rotors to fit ?
Thanks sean
Posted on: 2014/7/5 10:14
Subject Poster Date
     R32 rear brakes and rotors on a h165 diff ? meandatto 2014/7/5 10:14
       Re: R32 rear brakes and rotors on a h165 diff ? ddgonzal 2014/7/5 21:06
         Re: R32 rear brakes and rotors on a h165 diff ? meandatto 2014/7/5 21:28
           Re: R32 rear brakes and rotors on a h165 diff ? ddgonzal 2014/7/5 21:44
       Re: R32 rear brakes and rotors on a h165 diff ? bobthebuilder 2014/7/6 0:27
         Re: R32 rear brakes and rotors on a h165 diff ? ddgonzal 2014/7/6 0:37
         Re: R32 rear brakes and rotors on a h165 diff ? meandatto 2014/7/6 6:15
           Re: R32 rear brakes and rotors on a h165 diff ? ddgonzal 2014/7/6 7:36
             Re: R32 rear brakes and rotors on a h165 diff ? meandatto 2014/7/6 8:23
       Re: R32 rear brakes and rotors on a h165 diff ? meandatto 2014/7/6 6:14
