Re: turbo
From In front, and pulling away.Sometimes around Sydney....ish!
Davos, do it man, you won't regret it! Done properly, they are very streetable and lots of low tech fun! If you want the easiest way a suck thru is the best. Standard fuel pump on mine (A14) and makes 90 rwkw. If you run a blow thru set up, you can intercool it, but will need high pressure pumps, similar to efi.
Posted on: 2006/11/15 20:18
Lifes good when your on BOOST!
Subject Poster Date
     turbo davos 2006/11/15 18:59
       Re: turbo matty 2006/11/15 19:56
         Re: turbo dog160 2006/11/15 20:18
