datsun_guy wrote:
sorry if im hijacking this thread abit i thought it would be relivant um what would would make a hot street a12 is it possible to stroke them at all and how much? carbs to use and valve springs cams is it possible to use a auto flywheel in stead of the manual one to get a bit of weight down whats the best pistons to run what stroke and bore all this will heap me out and maybe alot of other people trying to keep there littel datos origanl
Can you stroke an A12? Yes.
How much? 7mm with stock parts.
Pistons? Use A15. [modified]
Bore size? 76mm, 76.5mm 77mm, 77.5mm* [*if you're game]
Auto flywheel? Auto's do not use a 'flywheel'
Bore & stroke? With a 77mm bore & a 77mm stroke you will get 1434cc & this duplicates the capacity of an A14 with a 'second oversize', or 1mm, overbore, but all in the low deck block.
