gear stuck
From Lemoore
anyone knows why my 1200 gears get stuck when i first start the car...i have to like force it to go in to 1st if not then i put it to second instead..pain the ass every ####in time..because after i get it going then it's fine after that..is it the clutch or trans...any one out there who can help....please...help me....
Posted on: 2003/3/14 20:51
haZardthis
Re: gear stuck
From Auckland, New Zealand
sounds like syncrow (not sure of spelling) rings to me. Try selecting 2nd and then 1st with out releasing the clutch, should go into 1st easier.
Posted on: 2003/3/14 20:58
Re: gear stuck
I agree with Brent, it could be the 1st-gear syncro rings. Reverse doesn't have synchros ... does reverse feel the same way?
First I would carefully adjust the clutch play, cause that might be it.
Start under the car as follows:
Clutch release lever play
Then, measure and/or adjust the pedal inside the car:
Clutch Pedal Play
Posted on: 2003/3/14 22:02
Re: gear stuck
From Lemoore
thanks dude i'll give it a try....i was having this problem for a while....
Posted on: 2003/3/15 11:02
haZardthis
Re: gear stuck
From Castro Valley,CA USA
It might be worn syncro's. This would happen to me on cold mornings. Worn syncros and cold thick gear oil.
I switched to a synthetic gear oil and the problem went away. It's a band-aid fix but it worked.
Posted on: 2003/3/15 11:51
Re: gear stuck
From Melbourne, Australia
i put thick "performance" oil in my box at first but all it did was make the gear change really chunky, specially when the box was cold. so i put the normal stuff in and its pretty good now, still chunky when cold but ive never had trouble where i couldnt select a gear
Posted on: 2003/3/15 11:53
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
