Browsing this Thread:   3 Anonymous Users
« 1 (2)
Re: IHI RHB32 Turbo
From Toowoomba, australia
well i didn't ask what was wrong with it but basicly it was no good they said it was going to cost about $1200 to fix but i can buy a new one for about the same
DAVE
Posted on: 2003/3/29 22:36
why go up and down when you can go round and round
Re: IHI RHB32 Turbo
$1200 is is bullsh*t for a turbo rebuild. Shop around, you should be able to get a basic rebuild for around $400-$500.
And Barpk, it is probably worthwhile getting a turbo shop to check it out before you put it on. And since it is a very small turbo, why not see if they can hi-flow it with a bigger compressor wheel. Or you could look for a slightly bigger turbo. I have thought about using one off an ET pulsar 1.5 litre. They are plentiful and cheap
Posted on: 2003/3/30 3:32
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
Re: IHI RHB32 Turbo
From Arlington, TX, USA
Those cooled by both should have an oil line in and out, and a coolant line in and out. Oil only will, obviously, only have oil lines in and out. I think most OEM turbos are oil-cooled only?
Posted on: 2003/3/30 3:36
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
Re: IHI RHB32 Turbo
From Brisbane, Australia
Barpk,
I think you'll find that turbo running out of puff for your A15. I owned a turbo charade and they only go to 6000 rpm and it was dying off near top end at 11psi. They are a very small turbo and heat up fast.
Myself and L18_B110 are trying something a little bigger. Garret GT17, I am still worried it may be a little small. Oh well I guess I'll just have to put a T25 intake wheel on it if it is.
My two cents.
Craig
Posted on: 2003/3/30 14:36
Re: IHI RHB32 Turbo
From Pakistan
NoPsi wrote:
Barpk,
Craig
mine isnt A-15 but A-12 i.e. 1171 CC.
i heard stock PSI for charade was 7 PSI only, did u modify the turbo to get 11 PSI? beside all i need is >10 PSI cos i am sure that with blow through setup carb will start to leak pressure.
Posted on: 2003/3/30 15:37
STRONG IS STRONGEST ALONE. PERIOD
Re: IHI RHB32 Turbo
Yeah, I T-pieced the charade and cranked the boost. Your choice of turbo will be good for around town. It will spool up damn fast but just don't expect much top end stuff.
Craig
Posted on: 2003/3/31 4:03
« 1 (2)
