A15 not reving
From Springwood NSW, Formerly Tas.
Hey everyone
I got the a15 in my 120y. I'm running an a12 head, a15 carb and exhaust manifold to std 120y exhaust system.. It runs, but won't seem to rev over 4.5k, could this possibly be because my exhaust is too restrictive? My timing is about 20-15 deg btdc
Cheers tom
Posted on: 2008/4/9 15:23
1978 120y Coupe.
Re: A15 not reving
From malta
is it idling or full rev when u reed 20-15 bdc???????
Posted on: 2008/4/9 15:26
Re: A15 not reving
Idle... I have played around with it varying from the standard 7-8 to roughly 20 where it sits now,
Posted on: 2008/4/9 15:29
1978 120y Coupe.
Re: A15 not reving
From malta
and it is still doing the same thing???? set it back to the 7 to 10 degree to get max torque and take air filter out. if that does not make any difference. unscrew a litle bitt the exhaust to see if it does make effect.
Posted on: 2008/4/9 15:33
Re: A15 not reving
From malta
they r set mostly at a little bit of high rev. try to rev it up and see what degree you take. sry i didn't post this before the other one
Posted on: 2008/4/9 15:34
Re: A15 not reving
Its a bit late in the night to go out and try right now, but yeah i'll do it in the morning, i have no where to unbolt the exhaust.. Its one piece to the end..
Posted on: 2008/4/9 15:40
1978 120y Coupe.
Re: A15 not reving
From malta
sry here it is the afternoon. i m amazed you have no flange from the manifold to the pipe and what happens if u need to get the engine out of the car
Posted on: 2008/4/9 16:02
Re: A15 not reving
Oh yeah got one of those haha, except it'd be loud and sound like arse... And probably not give me a true indication if it is my system.. Its only 1am here so its not all bad..
Posted on: 2008/4/9 16:06
1978 120y Coupe.
Re: A15 not reving
From malta
there s no need to get it out, all u need is untinted it a litle bit. to release the back pressure. i m sure it will make a lot of sound but it will give you an indication.
Posted on: 2008/4/9 16:22
Re: A15 not reving
A15 uses 1.5 inch exhaust, same as A12.
Too much. Set it back to 7-10 degrees.
By the way, a stock A15 should rev to about
4500, with no extra power if you rev it higher. But it should rev to 5000, if you hold your foot down. Add a Weber downdraft and she'll spin up to 6000 making power all the way...
Posted on: 2008/4/9 17:16
