Re: about to do a ca18de conversion into a ute any tips? i need help?
From perth
get a det motor and a de ecu. cheaper
remove turbo, it may be a little flat due to lower comp but its only for a while
even 100 hp in a 1200 will go good
you could even learn a bit of tuning before you go turbo as you will have a bigger margin for error
you could use nitrous on the low comp de
dazza
Posted on: 2008/9/16 12:04
Subject Poster Date
     about to do a ca18de conversion into a ute any tips? i need help? agrodato 2008/9/16 2:16
       Re: about to do a ca18de conversion into a ute any tips? i need help? Lachie 2008/9/16 3:05
       Re: about to do a ca18de conversion into a ute any tips? i need help? crzy_1200_ute 2008/9/16 5:42
         Re: about to do a ca18de conversion into a ute any tips? i need help? frankthedolphintrainer 2008/9/16 7:18
           Re: about to do a ca18de conversion into a ute any tips? i need help? Lachie 2008/9/16 7:40
             Re: about to do a ca18de conversion into a ute any tips? i need help? dazza1200 2008/9/16 12:04
               Re: about to do a ca18de conversion into a ute any tips? i need help? dattodude 2008/9/16 12:56
       Re: about to do a ca18de conversion into a ute any tips? i need help? louix 2008/9/16 12:55
