#1 A15 or CA18det
Datti Posted on: 2008/11/13 1:55
Cant decide wether to rebuild my A15 and work it or just put in a ca18det. Need help guys and gals?
Whats the max kw i can get out of my a15 and is it worth it? Reliable? Cheaper to just get a ca18det?
any helps appreciated, cheers.
#2 Re: A15 or CA18det
sidedraught Posted on: 2008/11/13 2:10
You wont get much change from 10 grand by the time you finish the CA conversion.
#3 Re: A15 or CA18det
PIGDOG Posted on: 2008/11/13 2:16
the most power you can get out of an a15...that will costs lots and lots of money and you will be able to build a decent CA and get it in the car for that kinda money
better question might be whats the typical power you get from an A15 without going too overboard
andy, im expecting change from $1000 to finish the CA18de+t ....but thats starting with an L series in there already
#4 Re: A15 or CA18det
hotrocket Posted on: 2008/11/13 2:19
i second that!!!
#5 Re: A15 or CA18det
perthute Posted on: 2008/11/13 3:33
a fully worked a15 isnt gonna be quicker than a STOCK ca18det
but i hate ca18's so i would say sr20det
#6 Re: A15 or CA18det
dattodude Posted on: 2008/11/13 3:55
Yes.
A15 pros :
- no fabrication
- you can use club registration if it's only used for club activity. Saving ~$1000/yr
- no wiring
- no cooling
- no big brakes
CA18det pros:
- smoother to drive
- more torque
- better fuel in city economy
- less maintenance
- you get a 5 speed
- big learning experience.
Basically a CA18 is a learning experience. An a15 is a quick fix that allows you to stay on the road with a 1 day install.
I learned a lot about engines, welding, cooling, suspension, wiring etc etc in my CA18 install. I've also taught a lot of other people as a result of the hard/stressful days of learning things the hard way.
#7 Re: A15 or CA18det
PIGDOG Posted on: 2008/11/13 4:39
with a decent a15 your probably going to have to do some kinda brake upgrade and will probably want to upgrade the cooling system aswell
but totally agree with the CA being a learning experience, after you do it you actually know how stuff works....which is quite handy if your modding cars
#8 Re: A15 or CA18det
LAGWAGON Posted on: 2008/11/13 4:50
CA... there is nothing like having the performance of expensive sports cars in the shell of a datsun and you'll learn lots. i know thats a simple answer but you asked a simple question
#9 Re: A15 or CA18det
1200rallycar Posted on: 2008/11/13 6:24
you want learning experience?.... turbo the a15
#10 Re: A15 or CA18det
PIGDOG Posted on: 2008/11/13 11:44
even more learning experience?.....turbo and efi the a15
