« 1 (2)
#11 Re: Simmo's 1200 CA18DET ute
dazza1200 Posted on: 2008/11/22 5:28
THROW OUT NOTHING
until car is finished.you may want bits of the body harness, plugs, relay sockets etc nuts, bolts, rubber grommets.......
you get the picture
there is a little grey plug near the fuse block that is for diagnostics. if you use factory ecu this only takes a couple wires to have it working.
dazza
good luck
#12 Re: Simmo's 1200 CA18DET ute
Simmo999 Posted on: 2009/1/6 10:32
its been a while, update
gearbox tunnel is fully welded in and the gear box painted. New freshly painted hardcover on! here is some pics
[img=http://img383.imageshack.us/img383/1286/dscf0016ni8.th.jpg]
[img=http://img383.imageshack.us/img383/7704/dscf0014ms4.th.jpg]
[img=http://img383.imageshack.us/img383/9410/dscf0013mq5.th.jpg]
not too far away now!
#13 Re: Simmo's 1200 CA18DET ute
jeffery Posted on: 2009/1/6 10:59
mmm does look very nice...
#14 Re: Simmo's 1200 CA18DET ute
BRUTE Posted on: 2009/1/6 11:04
who did you get your hardcover from?
#15 Re: Simmo's 1200 CA18DET ute
frankthedolphintrainer Posted on: 2009/1/6 11:42
i noticed a few posts ago you asked what else you could take out of the engine bay.... i would say to get rid of that massive relay box, you should only need half of them if any (put the ones you need in the cabin aswell)
#16 Re: Simmo's 1200 CA18DET ute
Simmo999 Posted on: 2009/1/6 22:04
cheers guys, i got the hardcover off ebay! it came with all fittings and struts, quite impressed with it myself!
#17 Re: Simmo's 1200 CA18DET ute
Grunterhunter Posted on: 2009/1/7 6:15
Nice work Simmo.
A CA had always been my plan for the ute, but I couldn't justify the time and expense......
I'll buy it back off ya when you're done
#18 Re: Simmo's 1200 CA18DET ute
Simmo999 Posted on: 2009/1/8 9:41
haha, i don't think so mate! i will be keeping her for a while after this BIG expense. It's guna be even better than before!
« 1 (2)
