« 1 ... 3 4 5 (6) 7 8 9 ... 22 »
#51 Re: 1k wags PV a15 t50 aka msdrift
perthute Posted on: 2009/7/6 12:20
ill be going there tomorro after picking up a new dizzy;)
and somthing elce :ph34r:
#52 Re: 1k wags PV a15 t50 aka msdrift
perthute Posted on: 2009/7/7 11:04
holley fuel reg
bonnet pins
shift light
and a new elec dizzy from weekend 1000 cheers man
#53 Re: 1k wags PV a15 t50 aka msdrift
datski620 Posted on: 2009/7/7 11:10
so is it going to run better now....have you taken it for a drive yet?
#54 Re: 1k wags PV a15 t50 aka msdrift
perthute Posted on: 2009/7/7 11:56
should be better with the fuel reg and the elec dizzy
i got a set of bonnet pins for the rear too ( will be easyer than trying to make a locking tail gate
#55 Re: 1k wags PV a15 t50 aka msdrift
K-DOGG Posted on: 2009/7/7 12:19
ooo rear bonnet pins,maybe get some nice xc falcon style ones that sit flush. cops will probly frown on pointy things stickin out the back. good to see the wag's still around! heres whats under the blurple, 3 tone 3 layer pearl red white n blue!
jpg  thewagoriginal2.JPG (38.38 KB)
7792_4a532f5384707.jpg 576X432 px
#56 Re: 1k wags PV a15 t50 aka msdrift
ROConnor Posted on: 2009/7/7 12:22
I had truble with my holley regulater, it restricted flowto much If I had it on 3psi the carbs would dry themselvs out. mind you it wasent a real good pump (wasent a peice of #OOPS# though?)
#57 Re: 1k wags PV a15 t50 aka msdrift
perthute Posted on: 2009/7/7 12:34
them rims are now on a 1000 coupe ( joels )
cheers for tellin me about the fuel reg ill keep that in the back of my mind if i have dramas
#58 Re: 1k wags PV a15 t50 aka msdrift
datski620 Posted on: 2009/7/7 13:36
so thats what is hiding behind blurple.....what else, how much bog did you use to get it straight hmmmmmmm
#59 Re: 1k wags PV a15 t50 aka msdrift
K-DOGG Posted on: 2009/7/7 14:16
It was pretty straight and rust free when i bought it,just the nose dent and a little bit at the bottom of the doors from memory,i basically rubbed it down and painted it then tossed the siezed A10 for my 1400+dogleg,pimped out the rear(does it still have the matress?) and fanged around in it. Every car i've had since then has been full of bog,but now i've got a welder i shouldnt have to worry....
#60 Re: 1k wags PV a15 t50 aka msdrift
datski620 Posted on: 2009/7/7 14:54
we are just wondering what surprises are there for us when or if jordy wants to do any main body work.....you really should have goot a welder a long time ago!
