Re: PCD on 1200
How much offset you can run depends on the wheel width and the tire size.
The stock offset is +30 mm with 4" wide wheels. Most 5.5" wide wheels with appropriate offset will fit under the fenders of a Datsun 1200. Most 6-inch wide will not fit inside the gaurds, but theoretically (with the right offset) it is possible. Utes can fit wider wheels on the rear.
Tires: if you have 13" low profile you can run any amount of positive offset, like these 9-inch wide watanabes:
Posted on: 2009/11/26 23:26
Subject Poster Date
     PCD on 1200 iDatto 2009/11/26 10:56
       Re: PCD on 1200 iDatto 2009/11/26 11:02
       Re: PCD on 1200 matty 2009/11/26 11:11
       Re: PCD on 1200 iDatto 2009/11/26 11:13
       Re: PCD on 1200 racetech 2009/11/26 11:14
       Re: PCD on 1200 iDatto 2009/11/26 11:16
         Re: PCD on 1200 ddgonzal 2009/11/26 22:10
           Re: PCD on 1200 iDatto 2009/11/26 23:15
             Re: PCD on 1200 ddgonzal 2009/11/26 23:26
               Re: PCD on 1200 iDatto 2009/11/27 0:57
