(1) 2 3 »
#1 Who have used ARP rod bolts on their A series engine?
1200GXman Posted on: 2010/1/20 11:43
I need some advice for myself and Racetech please.
#2 Re: Who have used ARP rod bolts on their A series engine?
ROConnor Posted on: 2010/1/20 11:49
I hav rod bolts and head studs But havent used them yet.
#3 Re: Who have used ARP rod bolts on their A series engine?
dattoman_1000 Posted on: 2010/1/20 11:49
Mine has them in it
But I didn't fit them personally
#4 Re: Who have used ARP rod bolts on their A series engine?
1200GXman Posted on: 2010/1/20 12:09
I need to know how they are installed. In the other thread called "Wie verstaan Afrikaans" we spoke about ARP rod bolts.
Apparently it is a V8 engine's bolts you buy. Clive informed us that they are a little bit thinner than normal rod bolts which cause them not to be center in the bolt hole on the conrod. I am worried about this. Another guy said you can get it center grind which I don't know what it means. We need advice here in South Africa to do this right.
#5 Re: Who have used ARP rod bolts on their A series engine?
Jordan Posted on: 2010/1/20 12:14
dundee is putting some in my a14 soon
maybe pm him
#6 Re: Who have used ARP rod bolts on their A series engine?
ROConnor Posted on: 2010/1/20 12:22
They are an a-series spesific kit.
Part No: 102-6002 'datsun A14 rod bolt kit'
In the yellow pakageing
#7 Re: Who have used ARP rod bolts on their A series engine?
1200GXman Posted on: 2010/1/20 12:37
Thanks Connor. Just the info I was looking for.
#8 Re: Who have used ARP rod bolts on their A series engine?
ROConnor Posted on: 2010/1/20 12:39
No wories
#9 Re: Who have used ARP rod bolts on their A series engine?
racetech Posted on: 2010/1/20 13:46
As Connor said.
Motown will import my set of A14 specific rod bolts.
What some of the ppl do use modify the V8 bolts to fit, works out cheaper, but I'm not convinced.
The only reason I can see them not buying A Series specific bolts is that they are much more expensive than say the L series kits. Looking at R750 for a A series kit vs L series kit of +- R500.
#10 Re: Who have used ARP rod bolts on their A series engine?
TJ-Flames Posted on: 2010/1/20 14:02
would it be possible to use the L-series bolts an an a14?
(1) 2 3 »
