« 1 2 (3) 4 »
#21 Re: ca18det fitting into ute
PIGDOG Posted on: 2010/5/9 1:26
is the gearbox up high enough? what box are you running? did you get the tunnel to suit that box? as they make a long and short tunnel. so if you have the short tunnel and long box the box will hit the floor where the shifter is before its anywhere near the right spot
but yeah i'd be saying it probably needs to lean forward a bit more
#22 Re: ca18det fitting into ute
bfunkdlux Posted on: 2010/5/9 1:32
im using a ca box, the ca g/box tunnel and the ca g/box mount mounted to the maddat g/box crossmember as described by madat. if you lean the engine forward to give, say 10 mm clearence with the firewall the tailshaft will be running through the cab (probably not the best idea for legal reasons lol)
#23 Re: ca18det fitting into ute
blob Posted on: 2010/5/9 1:37
datto13b wrote:
your gonna be in all sorts if you dont get a larger tunnel. unless its a automatica tunnel then it might be okay, but why would you bother spending all this money on this conversion when your not even gonna do it properly by cutting the tunnel? do it once do it right and dont be a tightass...
I see your point,
But using the standard tunnel has been done before by quite a few members.
The other thing to be wary of is engineers. I didn't approach my build as a 'tight ass', but my engineer really didn't want me to cut the tunnel out.
Yes, I know that has been done a thousand times too, and there are countless cars out there with it done that are engineered - But he's the one signing off on it.
So, Who am I to argue?
By the sound of it, it's probably more to do with the angle of the motor and gearbox placement.
If it is a maddat X-member give them a call, they've always been helpful with me.
#24 Re: ca18det fitting into ute
Dat82 Posted on: 2010/5/9 1:44
Exactly what Blob said , i honestly am not a big fan of cutting out the tunnel out and welding in a bigger one(no offence to anyone), it was hard enough cuting out my rad support to fit my intercooler . and i am not being a tight arse by doing it , you dont even now the reasons i am keeping the standard tunnel or what gearbox i am running. Everyone has different ways of doing things and thats why every build is unique
Hey Blob do you happen to have details of the engineer your going through?
#25 Re: ca18det fitting into ute
bfunkdlux Posted on: 2010/5/9 2:00
yeah i was planning to call him (gunna wait till monday) just thought id ask if any1 had come across the same problems and what they may have done about it.
thanks for all the feedback and advice
#26 Re: ca18det fitting into ute
perthute Posted on: 2010/5/9 2:24
did they send out the short tunnel has that happend to me after checking all my work i relized they sent the wronge bloody tunnel so i had to cut it all out :/
dont buy the brake booster kit it doesnt fit
i still think the sr will fit on the ca x member ;)for the guys thinking of the sr kit
and yer the ca x member sits 10mm to the right maddat told me this was for bigger turbos but i would rather everything be straight
#27 Re: ca18det fitting into ute
bailz Posted on: 2010/5/9 4:42
Quote:but why would you bother spending all this money on this conversion when your not even gonna do it properly by cutting the tunnel? do it once do it right and dont be a tightass...
Roflmao! thats funny as mate, so your telling me that because i choose to keep the original tunnel with no mods whatsoever that i am a tightass? lol, you just got sucked in by maddats infamous ca18det fitting kit which needs a bigger tunnel for removal of gearbox without removing the motor.... i personally find it easier to remove the gearbox attached to the motor for better alignment of the clutch etc... oh and it easier lol... and also your telling me that your bigger tunnels are better? lets see, a new tunnel, remove old tunnel, bird #OOPS# weld in a new tunnel, unless your a boilermaker/welder by trade an engineer wont sign that off... and you have possibly removed alot of the structual strength of the car... THE OLD SAYING "KISS!" its not rocket science
#28 Re: ca18det fitting into ute
bailz Posted on: 2010/5/9 4:44
oh and does maddat do it properley? alot of there stuff seems to be a well thought out but possibly not trialed?
#29 Re: ca18det fitting into ute
tommo73 Posted on: 2010/5/9 5:03
made all mounts myself(fits spoton)
made gearbox mount myself (fits spoton)
ca box in manual tunnel used but belted out with hammer fits
but would not pass enginerrs, to tight around box but fits
sounds like maddat kit needs custom fitting??
ca in race car fits spoton just needs more room to pass
i say build it your self, only u to blame if dont fit!!
#30 Re: ca18det fitting into ute
blob Posted on: 2010/5/9 5:37
PM Sent - Dat82
« 1 2 (3) 4 »
