Re: fitting trx rear brakes on 1000 front end. can this work?
From brisbane
Thanks very much mate!
Posted on: 2010/8/4 12:00
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Subject Poster Date
     fitting trx rear brakes on 1000 front end. can this work? Matto1kUte 2010/7/20 9:56
       Re: fitting trx rear brakes on 1000 front end. can this work? Dundee1000 2010/7/20 11:12
       Re: fitting trx rear brakes on 1000 front end. can this work? Matto1kUte 2010/7/21 4:38
         Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/7/21 5:06
           Re: fitting trx rear brakes on 1000 front end. can this work? benny 2010/7/21 5:27
           Re: fitting trx rear brakes on 1000 front end. can this work? ssskiwi 2010/7/22 3:22
             Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/7/22 5:31
         Re: fitting trx rear brakes on 1000 front end. can this work? Matto1kUte 2010/7/21 6:03
           Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/7/21 9:27
       Re: fitting trx rear brakes on 1000 front end. can this work? levey 2010/7/21 9:52
         Re: fitting trx rear brakes on 1000 front end. can this work? Matto1kUte 2010/7/21 11:36
           Re: fitting trx rear brakes on 1000 front end. can this work? PIGDOG 2010/7/21 11:39
           Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/7/21 11:42
       Re: fitting trx rear brakes on 1000 front end. can this work? Matto1kUte 2010/7/21 12:09
         Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/7/21 12:18
           Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/7/21 12:19
             Re: fitting trx rear brakes on 1000 front end. can this work? PIGDOG 2010/7/21 12:42
       Re: fitting trx rear brakes on 1000 front end. can this work? levey 2010/7/21 12:49
       Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/7/21 14:48
         Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/7/21 23:02
           Re: fitting trx rear brakes on 1000 front end. can this work? PIGDOG 2010/7/22 0:08
             Re: fitting trx rear brakes on 1000 front end. can this work? PIGDOG 2010/7/22 0:13
               Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/7/22 1:30
                 Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/7/22 3:17
       Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/7/23 23:29
         Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/7/24 0:50
       Re: fitting trx rear brakes on 1000 front end. can this work? andy-roo 2010/7/24 1:54
       Re: fitting trx rear brakes on 1000 front end. can this work? Matto1kUte 2010/7/27 2:38
         Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/7/27 4:06
       Re: fitting trx rear brakes on 1000 front end. can this work? PIGDOG 2010/7/27 9:08
       Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/3 3:44
         Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/3 4:50
           Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/3 5:47
       Re: fitting trx rear brakes on 1000 front end. can this work? dattoman_1000 2010/8/3 11:06
         Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/3 11:40
           Re: fitting trx rear brakes on 1000 front end. can this work? matty 2010/8/3 12:25
             Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/3 13:52
       Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/4 11:48
         Re: fitting trx rear brakes on 1000 front end. can this work? matty 2010/8/4 12:00
           Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/4 12:03
             Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/4 12:16
               Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/4 12:19
                 Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/4 12:32
                   Re: fitting trx rear brakes on 1000 front end. can this work? Dundee1000 2010/8/4 13:16
       Re: fitting trx rear brakes on 1000 front end. can this work? PIGDOG 2010/8/4 15:18
         Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/4 22:57
           Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/5 6:18
       Re: fitting trx rear brakes on 1000 front end. can this work? clyons8 2010/8/5 7:18
       Re: fitting trx rear brakes on 1000 front end. can this work? A14Sedan 2010/8/5 7:32
         Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/5 8:49
         Re: fitting trx rear brakes on 1000 front end. can this work? PIGDOG 2010/8/5 8:50
           Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/5 10:22
             Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/5 13:32
               Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/22 3:56
       Re: fitting trx rear brakes on 1000 front end. can this work? TUF-110 2010/8/7 10:15
       Re: fitting trx rear brakes on 1000 front end. can this work? PIGDOG 2010/8/7 11:07
         Re: fitting trx rear brakes on 1000 front end. can this work? steveo 2010/8/7 12:06
           Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/7 14:37
           Re: fitting trx rear brakes on 1000 front end. can this work? matty 2010/8/8 11:49
             Re: fitting trx rear brakes on 1000 front end. can this work? steveo 2010/8/8 12:36
               Re: fitting trx rear brakes on 1000 front end. can this work? D 2010/8/8 15:09
