Re: E15 is there a rwd g/box that fit them
From Millgrove Vic OZ
The E15T engine is in my experience very reliable, reasonably light, strongly constructed and worth doing as a replacement engine. I have one I built up in my VB11 van. On gas it made 180 FWhp with a modified T25.
The head problems they have usually result from cooling system faults left unattended such as clogged radiators.
Distributor problems result from moisture in electrical connections and distributor bodies. The dissys use a photo optical sender unit nearly identical to FJ20T and CA18DET's and are very reliable with good connections.
MRD (Murphy Racing Developments) in Bayswater Victoria has just run a high 10 second pass in their ET and it is very reliable.
I am looking at fitting one up with an A series 63A box to fit into a 4 door 310. I reckon they are great little engines that are under utilised for swaps.
Posted on: 2004/1/6 23:01
Cheers Feral
Subject Poster Date
     E15 is there a rwd g/box that fit them MattoRX7 2004/1/4 9:29
       Re: E15 is there a rwd g/box that fit them Dodgeman 2004/1/4 10:47
         Re: E15 is there a rwd g/box that fit them MadTimo 2004/1/4 10:50
           Re: E15 is there a rwd g/box that fit them MattoRX7 2004/1/4 11:13
             Re: E15 is there a rwd g/box that fit them ddgonzal 2004/1/4 17:36
               Re: E15 is there a rwd g/box that fit them tsillay 2004/1/4 20:43
                 Re: E15 is there a rwd g/box that fit them holeshot 2004/1/4 23:18
                   Re: E15 is there a rwd g/box that fit them converted 2004/1/5 5:58
                     Re: E15 is there a rwd g/box that fit them tsillay 2004/1/5 8:35
                       Re: E15 is there a rwd g/box that fit them MadTimo 2004/1/5 9:50
                         Re: E15 is there a rwd g/box that fit them MattoRX7 2004/1/5 10:40
                           Re: E15 is there a rwd g/box that fit them feral 2004/1/6 23:01
                             Re: E15 is there a rwd g/box that fit them barpk 2004/1/7 10:57
                               Re: E15 is there a rwd g/box that fit them holeshot 2004/1/7 12:21
                                 Re: E15 is there a rwd g/box that fit them shoom 2004/1/8 4:55
                                   Re: E15 is there a rwd g/box that fit them matbighat 2005/3/30 7:50
                     Re: E15 is there a rwd g/box that fit them pro240c 2005/3/30 8:21
                       Re: E15 is there a rwd g/box that fit them dazzasute 2005/6/14 14:57
                         Re: E15 is there a rwd g/box that fit them sr12 2005/6/16 11:42
       Re: E15 is there a rwd g/box that fit them blownb310 2007/3/10 11:48
         Re: E15 is there a rwd g/box that fit them ddgonzal 2007/3/10 13:07
           Re: E15 is there a rwd g/box that fit them datsun_guy 2007/3/11 10:43
