#1 WTB: EGR valve
Stefano Posted on: 2011/11/14 7:30
I'm after an EGR valve (either separate or as part of an inlet manifold). I really need one to get my ute registered, so if you think you can help please PM me.
Here's what I need:
http://datsun1200.com/modules/mediawiki/index.php?title=EGR
#2 Re: WTB: EGR valve
ddgonzal Posted on: 2011/11/14 7:54
Just the valve? You can get it from many Datsun vehicles, maybe even other brands of cars.
Or also the thing it bolts to? It doesn't bolt directly to the manifold.
#3 Re: WTB: EGR valve
Stefano Posted on: 2011/11/14 10:11
I would prefer as part of a manifold so that i can get the temperature vacuum switch also. Are the valves the same as the a12 on other datsuns?
#4 Re: WTB: EGR valve
Stefano Posted on: 2011/11/14 10:13
Sorry, I mean the thing it bolts to also
#5 Re: WTB: EGR valve
ddgonzal Posted on: 2011/11/14 10:34
The valves are all the same size, such as Datsun Bluebird etc. The flow characteristics are different each year but they will bolt on I believe.
All later A12 & A14 manifolds have the EGR cast boss on the manifold, but the passages are not drilled in most cases. So the EGR Body won't actually bolt on.
Here's another piccy from a JDM Sunny B310 looks like:
And here's a USA version showing where stuff goes:
#6 Re: WTB: EGR valve
Stefano Posted on: 2011/11/14 10:40
Yeah, I've been talking to Scott at maddat and he reckons if I get the valve then he can drill it in the the manifold and plumb it in the the extractors. So all I need is the valve and the switch, but if I get a whole setup I might replace some of the stuff I have
#7 Re: WTB: EGR valve
Stefano Posted on: 2011/11/16 23:26
bump, can anyone help? c'mon guys, go check those rusty old carbies sitting in the shed
#8 Re: WTB: EGR valve
Posted on: 2011/11/17 1:13
Threw mine out years ago. Go wreckers and get off a vanette or different car
#9 Re: WTB: EGR valve
datsa73 Posted on: 2011/11/17 3:46
What's with all these regulations?
#10 Re: WTB: EGR valve
DATUTE1 Posted on: 2011/11/17 8:31
I got a whole set up i was going to use in my ute. If you were still in Canberra i couldve lent it to you. I'll call you on Saturday when i get to the garage. Might be able to work something out. Thought you said it was easier to register in Adelaide.
