« 1 2 (3)
#21 Re: 1890cc A-series for sale
dattoman_1000 Posted on: 2011/11/19 7:24
To achieve that with an 80mm bore you'd need a 94mm stroke
Up from an A15's 82mm
I highly doubt you could offset grind an A crank to achieve this so would like to know what cranks and rods been used
And whether theres even any counterweights left on it
And what pistons would be used to achieve this
#22 Re: 1890cc A-series for sale
D Posted on: 2011/11/19 8:20
e16 crank is 88mm max and 1mm undersize grinding crank mains 88.5 or 89mm?
bores can go up to 81mm sleeved before combustion chambers are oof the mark
from too much offset. 94mm welded stroked crank would make it fragile on bores
due to bad RSRatio unless using fixed cast iron deck plate with sleeves.
#23 Re: 1890cc A-series for sale
Dion120Y Posted on: 2011/11/19 9:32
How long before this thing goes KABOOM!! pieces of engine everywhere
#24 Re: 1890cc A-series for sale
datski620 Posted on: 2011/11/19 9:41
you forgot to mention all the pieces coming out the exhaust praying traffic with shrapnal
« 1 2 (3)
