5 Speed Gear Box ID
From Toowoomba
I was sold this as a 5 speed gear box to bolt onto my A14...
Can anyone tell me what model gear box this is...What model dato/nisso did it come off?
I was sold it to bolt onto my A14
There is a grind between 2&3 so need to reco..
Where can I get parts etc..
Will this bolt onto A14, A15 ?
jpg  IMG_0888.JPG (70.70 KB)
10982_4ed0a4fc3ffbe.jpg 512X384 px
jpg  IMG_0889.JPG (46.64 KB)
10982_4ed0a508a9577.jpg 512X384 px
jpg  IMG_0890.JPG (53.34 KB)
10982_4ed0a51614b99.jpg 512X384 px
jpg  IMG_0891.JPG (13.66 KB)
10982_4ed0a51e01062.jpg 128X96 px
Posted on: 2011/11/26 8:40
Re: 5 Speed Gear Box ID
its a 60 seires - that will bolt up to an a14 or a15. you might need a different clutch cable- sometimes the end peice to the clutch lever is different on the gear box. you could also file it to fit.
is it a 4 or 5 speed?
its a nice strong box for a a 14 or a15
Posted on: 2011/11/26 8:47
That is a 60 series 5 speed. A pic of the lower rear half will tell if it's a 60A or 60L and these only fit on A series. I would reccommend fitting the throwout bearing off the old gearbox on to avoid any issues there on fit up. As for the crunch, the synchro rings are still available but I would also reccommend replacing the energising srings and lugs. They can often cause problems shifting. I had one recently that had thrown a energising spring and did not need a synchro at all.
Posted on: 2011/11/26 8:48
I've got the same trans to my A15. Very good upgrade.
Posted on: 2011/11/26 14:09
