Re: Few Quick Questions
From Seattle ,WA.
you can spray anything over almost any type of existing paint if you apply a seal coat first. A 2K epoxy is probably the best to seal the vehicle with then you can put whatever you want on top of it.
read up on spraying a sealer coat, usually w/epoxy its a slightly thinned version of full strength epoxy 10 - 15% acetone reduced, with that applied you can then walk away for quite awhile & not worry about surface rust occurring which I'd think in your area could be a real problem. you can do filler work on top of the sealer as well. regardless of what you do - read a LOT before doing anything, you'll be happier with your result if you do.
the clear is a polyurethane - see tech sheet - probably fairly decent stuff.
http://www.de-beer.com/TDS/en/TDS8-204_EC.pdf
Posted on: 2011/11/30 19:06
Subject Poster Date
     Few Quick Questions Sumith 2011/11/30 4:45
       Re: Few Quick Questions edp 2011/11/30 5:50
         Re: Few Quick Questions ddgonzal 2011/11/30 7:02
           Re: Few Quick Questions Sumith 2011/11/30 7:29
             Re: Few Quick Questions ddgonzal 2011/11/30 7:52
               Re: Few Quick Questions Sumith 2011/11/30 8:17
       Re: Few Quick Questions edp 2011/11/30 19:06
