« 1 (2)
Re: for the weight saving guru
From Launceston TAS
aluminium is one third the weight of steel and two thirds the strength. for what its worth!
Posted on: 2012/4/9 9:48
If they have steel inserts, well that's certainly a lot more re-assuring than if they were straight alloy, but I'd want to cut a few apart and find out just how much steel is there and if it is just like a helicoil/thread, or if it has a flat section as well so that the 'clamping' surface is steel too. If it had that all in place i'd at least say 'well it could be a lot worse' :) sort of thing, but to be perfectly honest - given the fact that _if_ they let go or failed, they likely wouldn't do it whilst sitting in your car in the driveway, but rather they'd let go under the most stress - braking or cornering most likely (cornering probably more so, due to direction of the stresses). And the harder the cornering forces, the more likely the failure.
And I reckon it'd be fair to say that if you lose a wheel mid corner, esp an outside one, that rolling the car would be practically guaranteed. You might not be killed, but it's possible, and the car would be wrecked beyond repair as well.
Posted on: 2012/4/9 10:46
John McKenzie
From Tasmania
I got a reply for the ones on ebay with the steel inserts.
"20 nuts weighs 400 grams from memory, so that would equal 20grams per nut."
Posted on: 2012/4/9 13:13
Proud member of " The Tasmanian Datsun Owners Group"
From Tasmania
Otomoto nuts are 21grams each
Posted on: 2012/4/13 5:58
« 1 (2)
