Re: A12 Distributor Swap to Electronic Ignition
A Premier is a brand of car. However I see you are in Pakistan so perhaps vehicle is a B310 Sunny?
The EI article lists different factory Datsun/Nissan distributors that will work. If the Pulsar or 1980s Sunny are common in your area, i would recommend the distributor from that.
Posted on: 2012/5/3 3:47
Subject Poster Date
     A12 Distributor Swap to Electronic Ignition nabeel 2012/4/26 2:33
       Re: A12 Distributor Swap to Electronic Ignition Dion120Y 2012/4/26 5:05
         Re: A12 Distributor Swap to Electronic Ignition ddgonzal 2012/4/26 5:44
         Re: A12 Distributor Swap to Electronic Ignition nabeel 2012/4/26 8:16
       Re: A12 Distributor Swap to Electronic Ignition nabeel 2012/4/27 17:33
         Re: A12 Distributor Swap to Electronic Ignition ddgonzal 2012/4/28 3:18
           Re: A12 Distributor Swap to Electronic Ignition nabeel 2012/5/3 2:46
             Re: A12 Distributor Swap to Electronic Ignition ddgonzal 2012/5/3 3:47
               Re: A12 Distributor Swap to Electronic Ignition nabeel 2012/5/3 5:22
                 Re: A12 Distributor Swap to Electronic Ignition ddgonzal 2012/5/3 6:10
