Re: Intro and Alternator Questions
Hi and welcome to the club. How do you like the A14 engine?
The later 620 alternator is a direct swap for a 1200 (A12 engine). The A14 uses a larger alternator than the 1200/620.
All FN alternators are, by definition, for use with external regulator. But there is a an internally-regulated A14 alternator with LS wiring. It uses the same T-connector: 1978-1982 internally regulated A14 alternator
But you have it wired incorrectly. FN type should be: F goes to a voltage regulator, not directly to the warning lamp. LS type can be connected directly to the warning lamp, but it is the L terminal. So you'll have to re-do the wiring (all two wires).
Posted on: 2012/5/18 2:16
Subject Poster Date
     Intro and Alternator Questions areintjes 2012/5/18 1:35
       Re: Intro and Alternator Questions Anonymous 2012/5/18 2:08
       Re: Intro and Alternator Questions ddgonzal 2012/5/18 2:16
         Re: Intro and Alternator Questions areintjes 2012/5/18 2:21
         Re: Intro and Alternator Questions ddgonzal 2012/5/18 2:21
           Re: Intro and Alternator Questions areintjes 2012/5/18 4:40
           Re: Intro and Alternator Questions ddgonzal 2012/5/18 6:49
             Re: Intro and Alternator Questions ddgonzal 2012/5/18 7:30
               Re: Intro and Alternator Questions areintjes 2012/5/18 15:01
       Re: Intro and Alternator Questions areintjes 2012/5/18 2:17
