Initial A15 single DCOE weber settings
From Sydney
Hey guys looking for an initial setting for my single dcoe setup on a stockA15.
After recently buying a used twin dcoe setup i am going to use one of these carbs
Stripped down i can see more light through the edge of the butterflys on one than the other carb ( more worn )?
So i have
34mm chokes
45 aux venturi
125 main jet
180 air correcter
F16 emulsion tube
45 f12 idle
50 pump jet
How does this look for a start
and is the carb with tighter butterflys the better choice?
Thanks for this im looking foward to this setup and would like a good place to start.
Posted on: 2012/6/13 7:17
Re: Initial A15 single DCOE weber settings
yes, use the one with tight throttle shafts. They shouldn't be loose at all.
* 32mm chokes is good for a stock A15 from B310 which has the high-speed cam with 6000 RPM max power.
* For a later Vanette A15, which has the low-speed cam, smaller venturis are called for.
* 34mm venturis are for A15 at 6500 rpm, such as using dual valve springs and the A12GX camshaft. Or 2-liter at 5500 RPM.
That is if I understand the Weber book correctly ...
Posted on: 2012/6/13 8:07
