Re: wheels alignment
From Melbourne, Australia
if the wheel is back and the castor rod is in-tact then the only other thing it could be is bent chassis rail, look between where the engine crossmember bolts up and the castor rod mount, should be dead flat. A give away of this being bent is that the swaybar mount will look mounted on an angle also. It's a problem my rally car has, it's bad enough the swaybar touches the sump at the front of the motor
Posted on: 2012/10/2 11:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Subject Poster Date
     wheels alignment mcdat 2012/10/2 9:45
       Re: wheels alignment SmUrF_11 2012/10/2 10:11
         Re: wheels alignment benny 2012/10/2 10:16
           Re: wheels alignment mcdat 2012/10/2 10:22
             Re: wheels alignment Anonymous 2012/10/2 10:31
               Re: wheels alignment 1200rallycar 2012/10/2 11:55
                 Re: wheels alignment mcdat 2012/10/3 6:36
                   Re: wheels alignment benny 2012/10/3 7:23
                     Re: wheels alignment mcdat 2012/10/3 8:35
                       Re: wheels alignment 1200rallycar 2012/10/3 8:46
                         Re: wheels alignment mcdat 2012/10/3 9:15
                           Re: wheels alignment 1200rallycar 2012/10/3 9:28
                             Re: wheels alignment mcdat 2012/10/3 10:07
                               Re: wheels alignment supafatto 2012/10/3 11:52
                               Re: wheels alignment stumackloud 2012/10/10 3:27
       Re: wheels alignment jmac 2012/10/4 10:01
       Re: wheels alignment BeeJJ 2012/10/6 1:11
