Browsing this Thread:
1 Anonymous Users
Speedo pinion |
Not too shy to talk
From Western Sydney
Hey guys,
Long story short, My 1200 speedo no longer works after I got my gearbox reco'd. I've checked the speedo cable and connection to the back of the cluster in the dash which is fine, I then moved onto the speedo pinion cog splines which looked abit worn down, ended up fiddling around with it trying to make a flush contact with speedo spline in the gearbox resulting in the speedo slightly fluctuating up and down but not managing a constant reading then it stopped completely. I'm thinking the speedo pinion itself has been worn down over the years not allowing it to make a constant reading, Does the 60a share the same speedo pinion cog as the 4 speeds or are they different ? I cannot find a 60a speedo pinion anywhere. If you think I may have diagnosed this problem wrong, I'm open to comments and suggestions.
Much Appreciated, Jake
Posted on: 2013/1/21 8:54
Re: Speedo pinion |
I believe the pinions are the same for 60a as for 56a. I've got them from ebay, but I think you may be able to get them new from Nissan. I should have part numbers somewhere. But yeah Bprojects on ebay works. http://www.ebay.com.au/itm/Speedmeter ... a2fd&_uhb=1#ht_2418wt_689
Posted on: 2013/1/21 11:05
Re: Speedo pinion |
Registered Users Contentmaster Usermaster
SpeedometerQuote: 56-Series Transmission and 60-Series Transmission
PINION (32703) 32703-18001 PINION ASSY-SPEEDOMETER (15T) 32703-18000 PINION ASSY-SPEEDOMETER (16T) $10.55 USD 32703-15400 PINION SPEEDOMETER 17T [White] $17.02 USD 32703-H1000 PINION SPEEDOMETER 18T [Blue] $15.67 USD
Posted on: 2013/1/21 16:06
