« 1 2 3 4 (5) 6 »
#41 Re: rear discs on h165 or h190
D Posted on: 2013/1/17 11:54
Benny lovely setup using Hoe calipers, how does the handbrake work or function on this setup?
RC I have the r31 setup on my also but clears much easier with small tubing on H145 and my
only guess is that the bigger tubing on the big H190 axles is the issues compared to h165?
#42 Re: rear discs on h165 or h190
1200rallycar Posted on: 2013/1/17 20:17
I think the issue is the lowering blocks mainly and perhaps the diff is cut a tiny bit too short. The 190 uses identical wheel bearing and backing plate bolt pattern to 165 so it can't be significantly different in diameter
#43 Re: rear discs on h165 or h190
1200rallycar Posted on: 2013/1/17 21:19
actually the wheel bearing was identical between 23 and 29 spline h190 now i think about it
#44 Re: rear discs on h165 or h190
D Posted on: 2013/1/17 22:11
didnt know you had lowering blocks but good info if the H190 axles tubes are the same.
#45 Re: rear discs on h165 or h190
benny Posted on: 2013/1/17 23:42
I run a 12mm alloy block on my setup paired with near flat JTS springs [reverse eye etc]. Surely it cant be too different to your ride height RC. I will be down your way at Easter, can do a compare then if you like.
#46 Re: rear discs on h165 or h190
benny Posted on: 2013/1/17 23:45
No Handbrake, its for the track car only. Was thinking of adapting a rotor and caliper to the diff pinion like some early Suzuki 4WD [beit they are drum type] but the concept is the same.
#47 Re: rear discs on h165 or h190
D Posted on: 2013/1/17 23:53
yep remember my old 2 stroker had such a setup. Im still looking at doing inboard disc setup with an IRS diff using Alfa discs and calipers handbrake setup myself.
Will be great to see your beast down south
RC. did you get prices on lowered springs most joints Ive checked do them for 90 a side if you supply them but did find one place that did them for 120 for both.
#48 Re: rear discs on h165 or h190
LittleFireyOne Posted on: 2013/1/20 4:08
willwood offer a simple park brake setup, I was thinking about going that route on one side to save the hassles. That offeres the question, will a small parkbrake hold a car on one wheel? going to have to ask some engineer friends I think
#49 Re: rear discs on h165 or h190
PIGDOG Posted on: 2013/1/20 10:10
datsport use the wilwood mechanical park brake on their r32 rear brake setups for 1600s and baz was saying its not the nicest caliper to use because of something to do with the adjustment
a single handbrake will hold the car, but i would doubt its legalities for road use
#50 Re: rear discs on h165 or h190
A14force Posted on: 2013/2/4 20:59
I stumbled across some pictures of my U13 rear disc set up.
« 1 2 3 4 (5) 6 »
