#1 What booster and master cylinder
Datrotor Posted on: 2013/8/7 13:17
What booster and master have people used with disk brakes all round that seems to stop good?
#2 Re: What booster and master cylinder
michaelpapa Posted on: 2013/8/7 15:27
I think a normal nissan 1400 master and booster will be fine
#3 Re: What booster and master cylinder
Datrotor Posted on: 2013/8/7 21:55
I don't know if a booster meant for a 70hp a series will cope stopping a car with 6x asmuch power
#4 Re: What booster and master cylinder
Datrotor Posted on: 2013/8/7 22:01
Probly should have mentioned that.it has a 13b turbo in it
#5 Re: What booster and master cylinder
old-tin Posted on: 2013/8/7 22:03
The booster doesn't affect overall breaking, just the level of input required.
#6 Re: What booster and master cylinder
Datrotor Posted on: 2013/8/7 23:00
Might add it also runs ford ba xr8 front brakes
#7 Re: What booster and master cylinder
old-tin Posted on: 2013/8/7 23:13
Not saying you shouldn't use one, all my datos have a small can booster and they are good enough but will never feel like modern breaks.
#8 Re: What booster and master cylinder
Datrotor Posted on: 2013/8/8 0:16
Yea no no dramas mate.i do think I will run 1 also thinking using a 1" master.just not sure what car to get them from
#9 Re: What booster and master cylinder
loosekid Posted on: 2013/8/8 0:44
Im using the maddat brake booster setup
Includes BBK bracket, new small can brake booster, 7/8 master cylinder, hydraulic clutch kit, new clutch pedal and rubber, and one way check valve
http://www.maddat.com.au/products/BBK1200.htm
Work's wonders with my 200b coilovers and ford shortend diff for 4 disk's all round
#10 Re: What booster and master cylinder
ddgonzal Posted on: 2013/8/8 2:52
haha, the power level of the engine has no effect on the booster requirements. Maddat booster works fine. So does the stock 1990-up Nissan factory booster. The only reason to upgrade the booster is reduce the pedal effort.
