#1 Painting chrome
mcdat Posted on: 2013/12/5 2:13
Hi guys what needs to be done to paint chrome?does it need sanding to dull it down abit so that the paint adheres to it?
#2 Re: Painting chrome
ddgonzal Posted on: 2013/12/5 4:44
Any finished surface should be cleaned and sanded before painting. Less than perfectly clean chrome will eventually shed the paint.
#3 Re: Painting chrome
Datrotor Posted on: 2013/12/5 5:55
Best to get it to bare metal and start fresh
#4 Re: Painting chrome
mcdat Posted on: 2013/12/5 6:42
Hey datrotor will the chrome come of with a sander or is it to hard as in density,ill hit it with coarse paper then finer paper.
#5 Re: Painting chrome
torino120 Posted on: 2013/12/5 7:03
I have been told that sanding the chrome down to a dull finish, etch priming and then painting is a good method to go. About to try it myself actually, I've got a spare chrome bumper which I want to replace my tattered bent old one and want it to be the same/similar dull grey like the standard 1200 ute bumper.
#6 Re: Painting chrome
Datrotor Posted on: 2013/12/5 7:18
It sands down pretty easy with a grinder mate that's how I did mine then primed and hy-filled .cone out sweet
#7 Re: Painting chrome
dennisg Posted on: 2013/12/5 7:25
I've used sandblasting to rough up the surface of the chrome for painting. It is probably better to use a commercial sandblaster for this as those for home use are quite slow.
Its better yet to strip the chrome off.
