Re: checking compression ratio
Ok so my pistons are the standard dished ones and bore is standard. So should I still measure the piston dish cc or is it 10? If I do need to measure the piston dish how do I do that? Sorry for all the q's. Still learning.
Also what' thickness head gasket should I go for?
Posted on: 2016/3/19 0:21
Subject Poster Date
     checking compression ratio dhadina 2016/3/18 22:35
       Re: checking compression ratio ddgonzal 2016/3/18 22:52
         Re: checking compression ratio fiasss 2016/3/18 23:19
           Re: checking compression ratio ddgonzal 2016/3/19 0:06
       Re: checking compression ratio dhadina 2016/3/19 0:21
         Re: checking compression ratio ddgonzal 2016/3/19 0:59
         Re: checking compression ratio dhadina 2016/3/19 1:02
           Re: checking compression ratio ddgonzal 2016/3/19 2:13
       Re: checking compression ratio Rallytwit 2016/3/19 3:34
       Re: checking compression ratio dhadina 2016/3/19 4:39
         Re: checking compression ratio ddgonzal 2016/3/19 9:07
       Re: checking compression ratio dhadina 2016/3/19 9:35
         Re: checking compression ratio ddgonzal 2016/3/19 9:47
       Re: checking compression ratio dhadina 2016/3/19 10:00
         Re: checking compression ratio ddgonzal 2016/3/19 22:13
