Re: Car Shakes While releasing the clutch after a complete stop
These symptoms are normally caused by a bad flywheel surface or pressure plate finish, for example, burned metal surface or oil contamination. If you have *any* shaking (even slight) with normal load that's another clue. There should be zero/none but it may be "OK" barely causing a problem
Posted on: 2016/4/20 10:51
Subject Poster Date
     Car Shakes While releasing the clutch after a complete stop Sumith 2016/4/20 8:10
       Re: Car Shakes While releasing the clutch after a complete stop ddgonzal 2016/4/20 10:51
         Re: Car Shakes While releasing the clutch after a complete stop datsunbeginner 2016/4/20 12:39
       Re: Car Shakes While releasing the clutch after a complete stop Rallytwit 2016/4/21 4:03
       Re: Car Shakes While releasing the clutch after a complete stop zabond 2016/4/21 22:39
