Browsing this Thread:
1 Anonymous Users
Re: Electronic dizzy coil issue |
Registered Users Contentmaster Usermaster
Coil - must never be wired directly to ground/earth. The earth is switched by the distributor points or the electronic module
This is also why the coil may not show a voltage when the engine is not running. The way to check for voltage feed is Voltmeter from Coil + to Battery -
btw, Ballast Resistor has nothing to do with Alternator. Ballast Resistor use depends on the coil (some coils require a resistor, others are designed to be used without a resistor)
Posted on: 2017/10/7 4:48
