Charcoal canister question?
From Melbourne,Australia
Hi guys im currently fitting the fuel system to my 1200 ute and have been told buy the engineer that I must fit the charcoal canister.I know that later 1200 utes came with one dose anyone know where the vapour line goes?.Im not sure if it goes to the tank or if it is t-pieced to the orange line that goes to the fuel/air sepaerator located in the RH rear guard any help would be great
thanks
Posted on: 2004/7/23 7:22
Re: Charcoal canister question?
The basic idea is that any extra fumes vented from either the engine or fuel tank go through the carbon, to filter the air when the engine is not running.
On US B210s, Yes it goes to the fuel tank vapor return line (actually teed into it in the engine compartment with a valve). The 1200s (no cannister) have a three-way valve on the firewall, one goes the fuel vapor return line, another to the crankcase and the third to the air cleaner (B110). In other words when the engine is off the vapors are (theoretically) 'trapped' in the engine crankcase vicinity. But when the engine is running, the fumes are drawn into the air cleaner (carb).
The carbon cannister is a much better idea ecology-wise and doesn't hurt performance either.
Posted on: 2004/7/23 7:45
Cool thanks mate do you know where the return lines goes onto the tank because on my tank I have 3 fittings one is fuel supply one has a orange line that goes to the seperator in the body and the other is a black line that goes to the seperator also should I just tee it to one off the last two lines I just mentioned?
Posted on: 2004/7/23 7:54
My advice is go to the public library and look at a Haynes (or similar) manual for a 1980 or so Datsun of any sort. The S110 Haynes manual shows a "typical" configuration including a fuel check valve, the separator and all the hose connections.
Posted on: 2004/7/23 9:35
From Dallas TX
I'm working on converting my A14 to a dual SU setup. Each carb has an overflow port that I'm assuming passes vapors or liquid fuel at times. I dont' htink my original carb was hooked up to anything so I'm trying to figure out how to plumb this up. Should I find a dual input carbon canister or tie them together and then to a canister? Do the carbon canisters have an output that goes back to the tank? My tank does have a 3rd line that I believe is a vapor return, but at this point it's not being used.
If anyone could direct me to a fairly low cost canister that woudl work I woudl appreciate it. I'm in the US.
michael
Posted on: 2005/12/9 20:18
