Re: Need help with drive shaft
From Philadelphia, PA
You can use the shaft portion from any drive line and have the ends from your old drive shaft welded on then balanced. Alot of speed shops in the USA do this with aluminum shafts.
Of course make sure the length and diameter of the shaft are correct.
Good Luck.
Posted on: 2004/12/15 22:11
P.T.T.P.
Keep it simple
Subject Poster Date
     Need help with drive shaft RMSPOWER 2004/12/15 16:40
       Re: Need help with drive shaft webbs1200 2004/12/15 22:11
