#1 new cam troubles
datsunb120 Posted on: 2005/3/30 3:04
i have resently put a new cam in and there is a gap between the head and the rocker posts, the pushrods are second hand a12 ones. do i need roller rockers or different pushrods
#2 Re: new cam troubles
L18_B110 Posted on: 2005/3/30 4:18
are you sure the pushrods are A12? A14/15 pushrods are substantially longer. That is the first thing to check and the most likely problem as far as I'm concerned.
reground cam or billet? if its reground then there cannot be a problem with the cam's base circle. Just completely loosen off the adjusters on the rockers and torque the rocker post bolts down - very important to use a torque wrench as they are stupidly easy to strip! And for the same reason it's not recommended to tighten them if the rockers are actuating the valve springs. You should be able to fit the pushrods with the rocker assembly in position. If you can't, I'd say you've got the wrong pushrods.
if its a billet cam and you still have this problem after confirming the height of the pushrods, then it would seem that the base circle has been increased on the cam. You would be entitled to an explanation from the cam supplier, and will probably require shorter pushrods.
btw, it wasn't necessary to remove the rocker assembly.
#3 Re: new cam troubles
MLS Posted on: 2005/3/30 4:35
Sounds like you haven't lined up the rocker posts correctly when you refitted them.
There are dowels in the bottom of the posts that need to line up with holes in the head.
If they are not lined up you would probably get about 5mm gap under the posts.
#4 Re: new cam troubles
datsunb120 Posted on: 2005/3/30 8:00
the pushrods are the same lenght as the old ones, when position the rocker posts there is about a 5mm gap and it still does not line up when the rockers are completly loosened
would smaller pushrods solve this problem
#5 Re: new cam troubles
L18_B110 Posted on: 2005/3/30 8:16
first, is it a reground cam or a billet cam?
there is also a very real possibility that you have the cam timing wrong, and when tightening the rocker assembly down with the pushrods in place, valves are jamming on pistons.
#6 Re: new cam troubles
Dodgeman Posted on: 2005/3/30 11:39
What make of roller rockers are they?
If they are the YellaTerra rockers, then you can't use the original pushrods at all as these rockers need a ball at the top & the original pushrods use a cup.
#7 Re: new cam troubles
L18_B110 Posted on: 2005/3/30 13:04
he asked if he needs roller rockers, so I doubt he already has a set. And the answer to his question is no.
the other thing he asked is if he needs different (shorter) pushrods. And the answer to that is also no, standard A12 pushrods will be absolutely fine if it is a reground cam.
Datsunb120, I can measure both A12 and A14 pushrods for you if you want to confirm you have the correct part.
#8 Re: new cam troubles
L18_B110 Posted on: 2005/3/30 13:38
OK, just went downstairs to measure this stuff. These are eyeball figures of the pushrods measured from outer extremities:
A12 151mm
A14/15 166.5mm
#9 Re: new cam troubles
datsunb120 Posted on: 2005/3/31 2:05
i know that the push rods are a12 ones as i tried to fit a14 ones when changing the head and the where to long and i still had a spare a12 pushrod laying around and i measured it up to the new ones and it was the same lenght
when i tightened the rockers i reset the crank to t.d.c to do the cam timing so maybe it was the valves opening up againts the pistons
and by the way who ever said that you cant put a camshaft in while the engine is still in the engine bay is wrong it was easier than having to take the engine out
#10 Re: new cam troubles
benny Posted on: 2005/3/31 4:15
make sure you CAM followers are now not sitting in the sump, if you never took the engine out...........
